Carter Montana | I think your in the ball park of what your going to see if the rate smoothing box isn't checked,, maybe a touch high though. I had the same problem with the speed in rough fields and had to lower the receiver from the cab roof to the hood of the tractor between the front wheels. The bouncing of the tractor in rough fields sent the speed all over due to it's sensitivity, and made the rate controller work that much harder. It helped considerably. I also had good luck in modifiying the control valve settings, once I figured out how they functioned, but I would try lowering your receiver first. | |
