Southern Ontario, Canada | Behind the seat you have to remove a plastic cover, there is a group of about 6 relays. You could try switching those relays around. I believe that they are marked. That relay sends a signal back to a solenoid that's part of a 6 bank solenoid pack in the hydraulic pump compartment. Will look for a schematic in the morning then I can tell you which one of those solenoid needs to be powered up for the pilot system to work
Just now looked up schematic and there is a blue plastic tie around the wire pigtail that goes to the pilot control solenoid
Edited by deewight 5/16/2015 20:56
