Posted 5/13/2015 09:21 (#4567524 - in reply to #4566697) Subject: RE: Oliver 550 cutting in and out
If it starts up again after setting just a couple of minutes it is probably the fuel bowl stem is clogged up in the tank. If that is not the problem, then replace the condenser and points next, then the coil.
