Decatur, IN | We have 2004 Challenger mt 565b tractor. The left arm flasher is not working bulbs are good. Book says fuse is f3 but there is not a fuse holder between f2 and f4. The right arm flasher has a fuse. So any ideas what is going on? the top of cab and rear fenders work. Also when you use the turn signals the top of cab shows your turning opposite of the direction you are turning but the arm flashers and rear fender flasher show correctly. | |
