I thought the Summary Reports would be nice to generate spray application records but am having problems with the applied gallons being way off from actual. It is the same error I see on the Info Screen also. I have the meter calibration very close to what the tank total is reporting. The applied volume is counting up faster than the tank is being used. Is there another parameter that needs set to match the meter cal? I tried ag leader support for this and many other questions this spring but I haven't had much luck getting any answers. They did suggest buying the higher priced systems they sell. LOL This board has been much more supportive. Thanks. Ted, wiring the foot switch and using Freeform really made it a usable system for me. I was going to return it and try another system but will probably stick with it now. I still think there are a lot of lose ends in the software! Thanks for the info on the wiring.
