Search Forums | Classifieds (181) | Skins | Language
F700 runs good on top 1/2 of tank
Skinhead
Posted 8/6/2006 10:36 (#33165 - in reply to #33080)
Subject: Re: F700 runs good on top 1/2 of tank
I pulled one tank off and the pump has a hose on it where it draws from the bottom through a screen, everything looks fine. There is an electric transfer pump on the RH side, wonder if I have a problem with it, I did replace it a year ago, but perhaps I have a voltage problem. I agree on the carb kit, it runs too good part of the time for it to be a problem. Since it starts hard, fuel is bled off, would you feel it would be the elec transfer pump or should I try to get a pressure check on the in tank pumps?
