Search Forums | Classifieds (59) | Skins | Language
IH 1460 combine engine gear case leak
jdg
Posted 8/2/2006 19:13 (#32047 - in reply to #31999)
Subject: RE: IH 1460 combine engine gear case leak
Did you replace the pilot bushing in the flywheel. If that is warn out it would be quite difficult to get a new seal to hold. Do not run this gearcase low or other expensive parts will need replaced. best of luck. jeff
