roaming | You can do coverage mapping with both systems. Can do as-applied mapping (showing different rates) with the Pro 600, but everything will have to be manually controlled, since you say you have no connection to the planter.
You can put the Pro 600 in your Case IH combine, if you have one, and use the EZ-Guide 500 as a GPS receiver for yield mapping, or add EZ-Steer or full autoguidance (either Autopilot or AccuGuide) to the combine.
Can use the Pro 600 to control compatible Raven or Rawson systems, if you have them, and can use the Pro 600 for performance monitoring in your Case IH tractor. | |
