| He is refering to the Case Universal Display Plus.
Make sure it is up to date with the most current firmware, your Case dealer can do this. You will need to connect the Outback to the Case Planter harness with a 9-pin to 5 pin adaptor (again, your Case dealer will have this) and configure the Outback to output GGA and VTG at 1Hz and 4800 baud rate.
The UD+ will have to be setup to allow GPS input for mapping. You will not be able to use GPS for speed, only the wheel sensor on the planter or radar speed from the tractor. | |
