Posted 4/16/2008 07:37 (#359057 - in reply to #359033) Subject: RE: Putting GS2 Rate Controller on Tractor?
SE North Dakota
I installed the rate controller on my 4650 so I could run my sprayer and my chemical caddy without moving anything around. Just plug in at the hitch pin and go. My wheels are set wide (88"), so I just bolted it to the side of the lower cab wall. There is plenty of extra wire to deal with, but just coil it up and tie it up out of the way. Works real slick.
