I have two module boxes with 4 vavles each. So it has 8 sections. I set the planter up in 6 sections 2 rows each. I looks like it will not allow in the Insight to use 6 sections. It wants to use 8 sections. When you do the clutch config and put in 6 sections it comes up with "does not match". So do I have to run 8 secitons and set up a 2-2-1-1-1-1-2-2 or can I just take the wires out of the 7th and 8th section so the insight is not "looking" for them? |
