OK, I want to make sure I have this right. From reading other posts I gathered that I must use a relay, SPST Normally Open, to send the power from my spray controller Boom sense wire (12V). Then on a 250 I need to open and close, with the relay, pin 8 (-), and pin 4 (EXT switch in) Does this sound correct? I ordered my pins from http://www.deutschconnector.com/ looks like a very good site. Another question, At some point I will get an EZsteer 500, does the cable that comes with it, to connect the two together, have the plug for the coverage switch? And if anyone reading this has an EZsteer hooked up in a Pickup truck, I would like to see pictures of your mounts. Especially if you have it in a 1999 Ford E450 Thank You |
