Brush, Co | I just got the 500 this spring and have little experience so far . I have a lot of different fields set up. Some fields have several a-b lines and free form patterns (cool) set up. I am still learning but from what I can remember each field stores multiple a-b lines, but I think if you are within a certain area all a-b-lines will show--not sure. My fields are up to 10 miles apart and even when I bring up a field, the a-b line will not show until I get with in a certain range of the field.
What I can't figure out is how to change from say,field 1- event fertilize to say, field 1 event spray, Says I have to rename the field, even though logging has been deleted.
I can tell you more as soon as I get back in the field.
The 500-ez-steer is a hole bunch better than the plus-ez-steer on a Spra-coupe,(using Omnistar),can't wait to try it with Auto-pilot on the MT.
Randy | |
