Posted 3/31/2008 23:38 (#346994 - in reply to #346796) Subject: Re: Outback S2 with E-drive
Soutwest Ks.
I have this problem using either waas or their Baseline HD. Offset will typically run .3' to as high as .8'. (3/10 or 8/10 of a ft.) This offset can change within 30 minutes sometimes, or sometimes even going through the field on a pass. Implements appear to be trailing correctly or at least consistently.
