I'm getting ready to revamp our 1770 seedstar planter. I have the new wedgebox and harness for gen. 2 so I can run seeding prescriptions off the 2600 display. In the process of updating I also want to be able to run Autoswath with my half-width disconnect. I have the rate controller kit but after reading the instructions, it appears that I will need some additional harnesses but it is a little bit uncertain exactly which ones are required. The instructions say that a "Master switch and constant power harness" is required to "extend the master switch and/or foot switch to the rear of the tractor" I can not imagine why I would need that for a seedstar planter. Sounds to me like that would be for a sprayer or NH3 setup that needs a master switch in the cab and constant power source for Raven valves. Can anyone confirm this? I'm also concerned about the front extension harness (another requirement that I don't currently have). Apparently this would connect to the rate controller harness on one end and plug into my 9 pin ISO connector on the other. However, that is where my seedstar harness currently plugs in. I am not clear on how that is supposed to be resolved. Anybody had any experience in this regard? My dealer has been putting in a lot of time and effort on this project but is not having much luck finding any answers. I am hoping someone here already has some practical experience with this. TIA for any help! Charlie |
