Posted 3/22/2008 23:40 (#339886 - in reply to #338779) Subject: RE: Trimble's true tracker implement steer on 1790 planter?
Home Hill North Queensland Australia
Hi First of all I must say I have never seen one let alone used one & my knowledge of hydralics is very basic. I was wondering wether you could put a bypass hose & valve around the control valve. When you want to run without the controller you could open the valve (if it is run off the remotes it will also need to be in Float position) & turn off the control valve (if this is possible).
Ian
