Who has the best valued Autosteer system?
Paul VDB
Posted 3/23/2008 21:27 (#340358 - in reply to #340321)
Subject: Re: Who has the best valued Autosteer system?
Burgessville, Ontario
Adam
All 8130 tractors other than 2wd should be Autotrac Ready. All you need to autotrac is a receiver, display, processor, keycard and a short corner post harness to autotrac. If you want the gs2 display you need a receiver, GS2 display, autotrac unlock and a short corner post harness.
The combine is probably GS ready and you need to add the steering wheel (ATU) or get the autotrac integrated into the combine. The ATU might be a good way to go as it can be used on one piece in the spring and combine in the fall.
Mapping decisions should be considered as well.
GS2 would be a good fit for your sprayer and combine. The plus for the sprayer is that you would see what you sprayed and you should not have any misses in field and as for the combine - GS2 has documentation loaded and you would not have to get a basics keycard for an original system.
Email me direct if you have any more questions about the whole setup. Most of these things will hopefully give you enough answers and questions to proceed with a purchase of a hands free system - no matter what the brand!!!
