| We have had the same thing happen to our combine. Found out it was the alternator not charging the batteries enough. The hydraulics won't work unless batteries are fully charged. They are electric over hydraulic. Put on a new alternator and also replaced old batteries as one showed as being bad. Has worked great since. I thought it was also in the hydraulic valves. It drives you half nuts sometimes before you figure it out. Hope this is helpfull. | |
