Search Forums | Classifieds (108) | Skins | Language
8930 hyd problem
striker782
Posted 7/20/2006 10:57 (#28249 - in reply to #28237)
Subject: RE: 8930 hyd problem
Grand Island, Nebraska
Sounds like the couplers are needing to get cleaned out. Some guys take off the coupler body and let them soak in solvent overnite then blow them out as best you can with air. This may or may not totally fix them as we have had to replace cartridges on some tractors to get them to work correctly. Also, make sure your male coupler tips are not badly worn where the balls latch on to the tip.
