Search Forums | Classifieds (88) | Skins | Language
poly fingers
Ham
Posted 7/19/2006 19:03 (#28038 - in reply to #28004)
Subject: Re: poly fingers
Blvd d'Espair Bowhill, Sth Aust
You can make them yourself if you have threading and machining capabilities. Or a machine shop Im sure could source the material and make them for you, if they know what size shaft and thread it is. The product to use is called Nylotron. Take an original finger to them and ask.
What Gleaner are you going to use them in ? I found they work OK for the table auger, but in hot conditions ( ie 100F plus ) they don't work well in the feeder beater behind the table auger in conventional Gleaners.
They tend to overheat and bend excessively and dont feed, and pull back into the beater drum.
