| My Trimble dealer called the other day and said that there was some new software for the reciver that will make it work better around trees. I have both SF2 and Omnistar HP and they both don't work to good around trees. The SF2 will converge faster, or rather it will let you auto steer sooner with less accuracy. Omnistar takes a while but will not let you auto steer till it has converged on the line. You can open up the convergence so that you can run qiucker but it just depends if you want accuracy of the start or not. | |
