Near Intersection of I-35 & I-90 Southern Mn. | We sell lots of Raven Accu-flow systems which are available in a single valve (Fast Close) or two valve configuration. We always recommend the two valve system although it is somewhat more costly. In low rate applications we substitute a smaller control valve rather than the standard valve that is normally used.
This setup should handle the lower rates. You should be concerned about even distribution across the bar. This is always a concern but even more so at lower rates. |
