Search Forums | Classifieds (35) | Skins | Language
JD Swath Pro on planters ?
IACSR
Posted 2/12/2008 22:25 (#308284 - in reply to #308020)
Subject: RE: JD Swath Pro on planters ?
We toyed around with it last year with a rate controller before deere came out with the correct harnessing as well as tested machines for deere and had quite good results. The key is making sure you make your measurements perfect and learn how to do boundaries and headlands correctly in the display. That will make a difference. The final part is fine tuning with the closing wheels tied up so you can see if you need to dial the timing of the shutoff forward or back. It does work though.
