Search Forums | Classifieds (207) | Skins | Language
JD 4840 with a JD 1780 Vac Hydraulics?
JDPlowboy
Posted 7/11/2006 20:36 (#25673 - in reply to #25666)
Subject: RE: JD 4840 with a JD 1780 Vac Hydraulics?
sw MN
The 48 will work fine and you can turn the press up to 2400 psi or a little over that. I have pulled a 7200 vac with a 4440 and 4640 for years. Good luck
