Sutherland, IA | Going to make the jump to auto-steer this spring and we're already in a Trimble RTK network. Looking for opinions on which Trimble receiver will work best for us. We have row crops so, the main uses will be for plating, spraying, sidedress, and maybe harvest. We do however have a 3pt tile plow and a pull type dirt pan that i would like to be able to use the RTK with so, the vertical error is a concern with the different receivers. I think my options are the 252,332, and i've came across some used 214 receivers from time to time. It seems like the 214 receivers are used a lot on earth moving operations. Are they more accurate than the 252 and 332 in this sense and are there any downfalls to the 214 as far as using one for autopilot? thanks | |
