Posted 2/8/2008 17:58 (#304815 - in reply to #303258) Subject: Re: Will EZguide work on 2388.......
Is the yield monitor that you have on your combine a rectangular black box or is it a smaller gray touch screen? If you take the fuse panel off the right side where the gear lever is do you see a gray electrical connector with 5 flat pins on it?
