Madison, Mn | I Am running an Outback S2 with a edrive on a JD 8100 MFWD tractor. The tractor is dualed up in front and I am pulling a 16 row JD 1770 NT pull-type planter.
I Planted with the edrive last spring and just could not adjust it to completely eliminate the little (wander) in the rows. I have adusted the sensitivity in the S2, the Steering responce speed, and the hydralic valve speed, but cannot get the rows perfectly straight. Is this even possible, or should I stick this unit in the tillage tractor? | |
