Guelph Ontario Canada | A JD sensor kit and display without the satellite will give you summary totals only. As noted you really need to georeference your data to get the most out of it. Without a receiver you should be able to use a data store module to pull off the summary data to a spreadsheet. Since you have to go to the work of running harnesses I would also talk to the local AgLeader guys and go with what you think will work best for you.
Edited by peth 1/20/2008 21:08
