Search Forums | Classifieds (1) | Skins | Language
Off Topic : Tree Removal from pastures?
Phil A.
Posted 7/3/2006 08:47 (#23695 - in reply to #23406)
Subject: Here you go!!
You need a med size excavator and a huge dozer. Put a thumb or finger point on your dozer adn cut roots and push out tree. Use dozer to pile. Immediately DO NOT let them lay for more than say 6 hrs. Use dozer to rough grade surface. Then spread GENEROUS amounts of grass seed and use JUNK harrogator to rub in seed. We have reclaimed nearly 10 ac. of over grown pature this way. One year after clearing begin to mow and mow and mow. We are having great luck using this method if questions please call. YEs the tire man's phone number is on speed dial for the first year or so but after that it is not so bad.
Phil
