| First of all you need to export the file as a shape file in Sitemate, then if you have a lot of boundaries to bring into SMS set the default file type found under "file-general options-path" to Trimble (Version 5.5 & above) & select search sub folders.
Then click import & SMS will automatically search you default card reader drive for shape files then it's a click through process to bring in all the files in one go.
If the boundaries had been created with EZ-Map then the grower, farm & field names will also carry over into SMS. Nice import once you get it set up. | |
