| Nice job and I am sure lots of work. Some things occurred to me while looking at the pics. Did you do anything with the wobble box on the sickle. That has been an issue on our heads. Also did not notice and can't go back to look without loseing this note, is it a flex head. Did you drop the plate next to the sickle drive and inspect the linkages. There is a joint under there like a tie rod end and none of ours would grease thus wore out and waiting for a mess to happen. Found some cracks etc too so had to replace some of the parts under there. Those heads take a beating when running on the ground. | |
