Central NE | They start well when they are alone... this one was setting on a very slight slope then progressed into a slope that you might be able to sled down. It was parked in reverse with a 5' bushhog setting on the ground attached to the 3point. Next morning it was gone.
Ready for a long sentence?...Somehow it rolled backwards, started in reverse, and continued down the hill for a 1000 yrds, into a creek full of water, ran till it ran out of fuel, spinning the rear axle, burying the rear end, sliding the batteries to one-side, shorting out the positive side, frying the wiring harness from the dash all the way to the generator, taking the generator also, submersing the rear end, filling housing with water, catching a branch between the steering wheel and throttle.
Poor girl fried the leaves of the tree above the exhaust.
Remember, there is a bush hog attached....
Be Safe
Gayle
(062300_1756[00].jpg)
(062300_1756[01].jpg)
Attachments ---------------- 062300_1756[00].jpg (94KB - 1142 downloads) 062300_1756[01].jpg (86KB - 1134 downloads)
