| My dealer is telling me this machine has the "extended wear package" in it. The tech guys say it is stainless steel, heavier chains and thicker steel all this for $4500.00 . The tech guy also really ran down the 50 series because of the excessive wear problems. He says these guys buy these things cheaper not knowing what is inside and then really paying for it when they go through an inspection. In our case we are trying to replace two machines with one so it will get more material run through it. We will also keep one 9610 that will cut along side it or should I say on the other side of the field. | |
