Storing wheat
Joe
Posted 6/28/2006 10:56 (#22539 - in reply to #22491)
Subject: RE: Storing wheat
EHoff has good advice as I have used Reldan in the past with good results but not the newer chemical. Spraying the bins down first helps, or if you have heat in the bin turn up the heat and run the fan for a few minutes before fill. Also, as I put the first few thousand bushels I drop a few Phostox pils in the auger from time to time. Don't run the fan for a few days if you drop the pills in though. I started doing this with corn also to help kill any wevils that are already in the floor/bin. So far so good, Joe
