| Indiana: I think you baler is similar to our Claas 66. We are able to alter the size of our bales. On ours it has a guage on the front for bale pressure. Depending on how big of a bale you want you just watch the pressure guage. As soon as it is in the yellow region you can wrap a bale. You are limited some with the fixed chamber as it doesn't make a good bale any smaller than what is available in the yellow range- green or lower pressure doesn't work although Dad can finish out a bale that is smaller it just isn't as tight. | |
