SE PA | I'll second the motion for the baleskiis. But I'll also say that you ought to get the hyd tension, no matter what. It's pretty easy - turn the knob, and watch the pressure gauge, vs busting your knuckles on the hand cranks. If you deal with varying humidity, you have to change the tension, as we bale after dark, we HAVE to loosen the tension, or the bales become unliftable. Usually need to increase for straw, but we like our bales around 45-50lbs, no matter what it is. We can't sell anything heavier than that.
Rodney | |
