Ethridge, TN | This started out as a 28' trailer, picked up at a sale for $400. Decking was all missing, but the steel was in pretty decent shape. I'm long tired of climbing up on things, so wanted my unit close to the ground, there is a slide out step on the front corner of the drop. Put the short trailer in the shop, measured 8' back, and cut it. Everything down low is what I added to the trailer, 20'. Tanks are 1550's, usually only run 1300 in each, sprayer has a 1200 tank. Plumbing on the lower deck, runs under the deck, so it's out of the way for loading pallets/shuttles. |
