Ontario Canada | Small frame 7's are completely different than large frame tractors. You need to look behind the fuse panel behind the seat. Lower LH side ( RH if you're looking behind the seat ). There's usually some room there where some wiring is laying, could be slightly lower than the fuse panel itself. There may only be the square 4 pin connector. This is what you use the atu harness to go inline with. You need to get a power adapter harness for the 2 pin square connector on the atu harness. PF80873. Or make one from scratch.
Edited by GreenDaver 11/30/2012 09:08
