MO | I just traded for a 4410, it has a E-pro II for the rate controller and running the accu-booms. My old sprayer had a Outback STS system in it. I sprayed a little with the 4410 trying to use the light bar in the E-pro and I HATE it compared to the guidance of the STS. The STS was so much easier to follow. So I've pretty well decided to put some sort of steering in. Would I be happy with a smart steer on WAAS using it in last pass mode 95% of the time, and in terraces 50% of the time. I will be spraying pretty slow most of the time 8-12 MPH. Or what is another economical solution? I could possibly be using a CFX 750 in the planter tractor next spring, so there is a possiblity of swapping that if need be. THANKS alot for any suggestions, this is my first big step into guidance past the STS. | |
