Minnesota | I think you are leaning the correct way. I assume you are going to install hydraulic vehicle platforms? The 8130 would be fine with either unit, although depending on your planter using advanced seed tube monitoring and row shutoffs I would lean toward agleader.
Sprayer, Integra can be used with application modules and replace a Raven or other is you desire. Not familiar with a chopper. If you are steering the 9600, can easily take the next step and add yield monitoring to gain much more benefit from your display.
If all you are doing is steering guidance, stick with the Versa display. Its a very nice screen with all the same operation as the larger Integra. You just dont pay for the bells and whistles. | |
