Buffalo IL | Van trailer works great. I fill from the bottom can fit 1 pallet of spray start and two Mini bulk. The chemical inductor was the best purchase makes loading and mixing chemicals a breeze. can slam jugs down and rinse them out and mix AMS thru it too. $1500 well spent. The dozer is 1957 Allis chalmers HD11B w/ 516 Buda diesel. Oil field blade only 8' wide for hauling without permits. Needs undercarriage and about impossable to find parts. Most parts i've gotten from a guy in Canada.
The Mix 30 won't freeze, but gets real slow. It seperates out after sitting and that tank is shot and am going to cut the top off and feed out of it as the solids are all in the bottom from sitting too long. | |
