| Well I have a theory as to why they set it up that way. Not 100% sure, not even 50% sure if this was the thought they had when setting up the pivot point.
When you drive down the road the right track is always to the curb where primarily rocks, loose chunks of pavement, etc. You're more likely to run into obstacles with the right track on the road and that side will be able to cushion the blow
In the field if I see a rock big enough to lift my machine off the ground I'm gonna stop and move it. | |
