SC, MN. | I DON'T KNOW WHAT MODEL OF PLANTER YOU HAVE, HOWEVER THE NO-TILL/ MIN. TILL IS DEFINITLY GOING TO WEAR OUT PARTS FASTER.
THE NEW JD. ROW UNITS ARE MADE OF (DUCTILE CAST) THEY ARE CONSIDERABLY STRONGER. YOU CAN GET OPENERS THAT ARE THICKER, I HAVE SEEN W/ THE NORMAL OPENER DISKS IN NO-TILL THEY WILL WEAR THIN BEFORE THEY ARE WORN DOWN IN DIAMETER. WHEN YOU THINK OF THE PARTS YOU REPLACE ON YOUR FIELD CULTIVATOR AND THE WORK IT DOES BEFORE THE PLANTER IT DOES NOT SEEM AS BAD. | |
