| It's beyond a seal kit. The key was frozen and it had to be ground to the shaft to disassemble. There is a groove on the shaft at the seal and internal wear. Going to gamble on one off e-bay Item number: 7629811183. The NH dealer is 60 miles away and wanted $377 for this pump. Typically these motors should be in the $150-300 price range. Also needed to kit the master brake cylinder. NH said no kit available - new $249. I took the casting numbers into our NAPA auto parts store. $149 new & $25.64 for kit.
We're in NE OR, have had a wet spell. Just started swathing this afternoon on first cutting, weather-wise the window looks okay ;>} http://www.weather.com/weather/ten day/97850?from=36 hr_fcst10DayLink_undeclared
Many thanks for taking the time to answer. | |
