SE South Dakota | Marc making sure the linkage from the lever to the actual valve is operating freely would be the first item to check. Does the remote hydralic valve, ie a remote cylinder work well? If you need help call Jones Repair, Pipestone 1-800-752-2634. You could change the filter and see what might change(cut the old one open to see if anything is in it). I think the steering will be the last thing to fail with low hyd. pressure. | |
