Posted 10/19/2007 03:46 (#222652 - in reply to #222404) Subject: Re: Trimble RTK help please
Josh, I think you are right with the assumption that the base is cause of your problem. Your 500 just can use those satellites which the base is able to see. If there are obstructions in eastern direction from the base you won´t be able to use eastern sats in field although you have clear sight to the sky. Maybe you can check the number of satellites, both in field and base at the same time?
