Posted 10/15/2007 23:13 (#220149 - in reply to #219850) Subject: RE: Diesel Truck Leaking Down Fuel
southern Illinois
we just had the same problem on a 466 ih truck, it had to be pumped up to start it if it set overnight, finally replaced the prime pump and it holds now. that was our problem you might check that, and pump the prime pump up before you crank for 10secs or you will be buying a high priced starter before long.
