Posted 9/30/2007 23:18 (#212501 - in reply to #212389) Subject: Re: Greenstar display question
Redfield, SD
What is the processor programmed to? Should be yield mapping. What version of software is on the moisture sensor? Should be either 5.60A(4/5volt system) or 6.60B(2.5volt system). The processor should be programmed to 6.60D. If you have a 2.5 volt system don't program to Harvest Doc as then you will need a keycord with Harvest Doc on it. Let me know if this helps.
