Well, I said I was going to post some pictures of my burndown. Glyphosate vs. Gramoxone in a field where soybeans have come out of the ground and the stem is showing. For the Glyphosate: Found a spot where the beans were up, took a picture and then sprayed at a rate of 40 oz./a. It was raining for about a week before the application. Stayed dry after application and baked the ground. Beans were having a tough time trying to go through the crust. The beans in the picture were right in the crust layer and they stayed there until we got a little sprinkle and softened the crust a little bit. Still waiting for more rain to get the rest of the beans out. Anyway, the beans under the crust faired better than the ones in the crust. In my opinion, the glyphosate did not hurt the beans, it was more the crusting problem than anything. As you can see in the picture the beans did make it through eventually and the rest of the field doesn't look that bad. I actually had quite a few beans that broke their own neck trying to go through the crust. If I was in the same situation again I would spray the glyphosate again. For the Gramoxone: Picture was taken in a different field with lighter soil which didn't bake to a crust. As you can see in the picture, some beans were actually pushed out of the ground already before I sprayed with Gramoxone. ( 35 oz./a ). Well, it didn't seem to bother the beans at all, they were perfectly healthy and all the weeds were smoked. Definately the safer way to go, but 4 times as expensive. Conclusion: I think that at the 'hook stage' spraying the beans with Glyphosate or Gramoxone should not be a problem if absolutely necessary.
Edited by Clay-All-Over 6/4/2006 08:26
(tobesorted 100.jpg)
(tobesorted 071.jpg)
(tobesorted 082 (420 x 315).jpg)
(tobesorted 087 (420 x 315).jpg)
(cracked neck (576 x 522).jpg)
(stuck bean (432 x 328).jpg)
(tobesorted 101.jpg)
(tobesorted 072.jpg)
(tobesorted 073.jpg)
Attachments ---------------- tobesorted 100.jpg (71KB - 926 downloads) tobesorted 071.jpg (96KB - 974 downloads) tobesorted 082 (420 x 315).jpg (62KB - 937 downloads) tobesorted 087 (420 x 315).jpg (58KB - 954 downloads) cracked neck (576 x 522).jpg (80KB - 947 downloads) stuck bean (432 x 328).jpg (42KB - 910 downloads) tobesorted 101.jpg (84KB - 937 downloads) tobesorted 072.jpg (95KB - 933 downloads) tobesorted 073.jpg (74KB - 929 downloads)
