mid minnesota | will a 92 ford f250 8 lug rims fit on a 98 chevy 2500 8 lug???? thanks Dylan |
Nebraska, The land of corn and cattle | Im not sure about that new of a chevy, seems to me that they changed sometime and theyre different but dont quote me on it. Now on older stuff say pre 90 for sure then yes a ford will fit chevy but not the other way around |
Beresford SD | I think bolt pattern is the same but center hole smaller on one. Not sure which is smaller. |
west central Iowa | I think the ford had a bigger center hole so it should work on the chevy but not vise-versa, but the offset might be different. Just google wheel fitment guide and there are lots of hits on of them should tell you. |
| Bolt pattern is different. GM is 8x6.5, ford is 8x7. close, but it doesnt work. I've tried it. |
Brazilton KS | 92 ford will fit a chevy 8 bolt.
Sometime later ford changed to a different bolt circle that is about 5mm bigger diameter. It's different, but not very much...if you are capable of much of anything you can make them fit.
Chevy always used a smaller pilot hole, but the larger pilot fits. |
mid minnesota | Thanks everyone. |
Heil Harvesting, Ulysses KS/Limon CO | 99 was the size change and then the brains decided in 05 to change the offset... |
| Sorry for the bad info. I didn't read the post good enough. The ones I tried were post-99 |
wc in | a 97 ford 250 will fit a 87chevy but not the other way around. |
